Configure Spoof Detection
Configure spoof detection to prevent IP spoofing.
For more information about this feature, see Prevention of IP Spoofing within a VLAN.
  1. Enter GigabitEthernet Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
  2. Enable or disable spoof detection:
    spoof-detect [port {slot/port[-slot/port][,...]}] [enable]
    no spoof-detect [port {slot/port[-slot/port][,...]}] [enable]
  3. Enable or disable auto-recovery on a port:
    auto-recover-port [port {slot/port[-slot/port][,...]}] [enable]
    no auto-recover-port [port {slot/port[-slot/port][,...]}] [enable]
Enable spoof detection:
Switch(config-if)# spoof-detect port 1/1 enable
Enable autorecovery on a port:
Switch(config-if)# auto-recover-port port 1/1 enable
